Headstock design and specs. http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=13558 |
Author: | Ronstorm [ Sat Sep 08, 2007 3:50 am ] |
Post subject: | |
Hi fellas.... I'm a new builder, having built several over the past year, and need some help on headstock design.....namely tuning peg placement and spacing. With my first few builds, the peghead placement was pure luck!!! I'm wondering if there's any formula or "best practice" that it the rule. Any help would be appreciated. Ron Thompson. |
Author: | JJ Donohue [ Sat Sep 08, 2007 4:10 am ] |
Post subject: | |
Welcome, Ron! Here are a few quick suggestions: 1) look at some plans 2) Check out and measure some guitars at a guitar center 3) Paper and pencil and design your own using your imagination Basically, the strings should pass through the nut slots without interfering with other posts. You'll be able to see that in your full scale layout. Good luck |
Author: | James Orr [ Sat Sep 08, 2007 4:25 am ] |
Post subject: | |
Hi Ron These are the hole locations on mine: Hole 1: 2" above nut Hole 2: 3 3/16" above nut Hole 3: 4 3/4 above nut They're all 1/2" in from the side. Hole size depends on your tuners. |
